To program the first code, press the reset button once, then enter your 4-8
digit code on the exterior keypad, then immediately press the middle
lock button on the exterior keypad. You will hear a beep. This signals
that your code has been accepted.
To program the second code, press the reset button twice , then enter your 4-8
To program the third code, press the reset button 3 time, then enter your 4-8
I
conclude that this dorr lock is better that is appear. Is not a 2 codes
door lock, it's a 3 codes one.. and the problem you have is the third
code not reset. You can put the same code in each third emplacement. you
have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
Translate this page
Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Mine did that too for a month. Make sure all the batteries are new alkaline batteries of the same brand, and remove them for a few minutes (if already installed) and replace them in the unit. I reset my code as well afterword. Did the trick for me.
Locate the small round reset button near the left side of the circuit board (Red or Black).
To program, press the reset button once, then enter your 4-8
To enter a second code, follow the same procedures as in step
3, but this time press the reset button twice then enter your code.
I
I guide you...
I
I guide you...
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you want to reset the lock prior to entering in your new master code and any other access codes you wish to let others use.
It is easy and straight forward to program and use.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
