Question about Jet 3 Ultra Power Chair
Constant flashing lights,all three of the red, all of the yellow and one green. The chair was not at a full charge. I traveled approximately 20 feet, then I turned the chair around. Next ,I turned the chair off. When I returned to use the chair there was no power and all of the lights were flashing rapidly and repeatedly.
    Novelist:
  • 232 Answers
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Posted on Oct 29, 2010
SOURCE:
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Only two red lights show after some traveling.
It takes 5-6 full charges to brake a battery in. The first charge is 90%, then it increases. Also make sure that the caster and anti tilt wheels are free of dirt and any restrictions. Make sure that you don't exceed the weight capacity - most chairs are 300 lbs on a flat, hard surface.
Mar 14, 2013 | Health & Beauty
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
553 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
