Panasonic PV-GS300 Mini DV Digital Camcorder Logo
Posted on Oct 29, 2010
Dew detected on screen, camcorder shuts off - PV-GS300
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Oct 29, 2010
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251243
Points
49
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
DEW DETECT error when I turn on my PV_GS300 mni dv panasonic camcorder, and it shuts off automatically
I Have a PV - GS300 Panasonic Camcorder. It first had a problem being Dew error detected. When on auto focus it blurs and out of focus by keeping the camera still. Should I repair it or buy a new...
The problems you list are common and very repairable and can usually be repaired fairly inexpensively. However, they are not user serviceable problem and will need to be repaired by a qualified service technician.
3helpful
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
9helpful
11answers
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
2answers
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
