Top loader machine has power and goes through the normal cycle wash/eco rinse/spin fills with water when has too and empties, the only thing is when in wash cylce it doesnt agitate and when in spin cycle the bowl doesnt spin? any suggestions would be helpfull pls
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
make is westinghouse model lt955s
