Question about Homelite Garden
Ive got a homelite 720 watts generator and after a month from my purchase it wont start at all. i asked the dealer and they told me that the ic inside of the genset is busted. i told them if they have spare for that and they said they dont. so can u help me find this part so i can use my genset again? since my purchase i didnt really use this genset at all. im wondering if i purchase the right brand of genset. need help!!!!!!!!
  • Homelite Master
  • 819 Answers
Please list your model number when posting and I might have found part number for you.
Go to homelite.com service and support, find parts, parts locator, model # if you cannot find model number go to product line, homelite, then select generator, without model number you will have dozens of generators to look at.
Posted on Oct 29, 2017
6ya staff
SOURCE:
Anonymous
  • 72 Answers
SOURCE: Colemen powermate Generator 6875w 5500
GENSET ALL PROBLEM FIXES - 2 PARTS
My answer:
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers are related to the fact that people don't read the OWNERS MANUAL first, and just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR without OIL in the units to begin with!!!! (See esp #3 and Final Notes below as well)
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home Depot Store, and it's still under warranty - then you will have to contact that outlet, and see what they have to say or hopefully can do for you.
Esp all those Gensets that are Made in China and have flooded the USA market in the last 10 years or so - no thanks to our representatives in WASH DC that's for sure. It's a wonder this country even functions with all this "inferior" Made in China JUNK that keeps prematurely failing before it's normal time. Sad to say the least!
Some other obvious things to CHECK for that may be the cause of a NO start condition even after adding proper gas & oil to the brand new Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under the gas cap that should be removed according to your manual if it states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token (even if the Genset is or isn't brand new) does it have an in-line fuel filter anywhere in the gas line? If not then esp read #5. Always check as well the AIR FILTER for proper cleanliness (if oiled type), or clean appearance if it's a paper element type. Clean or replace as needed!
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an "Electrical ON-OFF Switch" usually a single-pole single-throw type btw, and it can go bad with high usage)? Does it move freely from OFF to ON? Is it working properly? Test it using a known good quality DVM or OHM meter! It's contacts may have become tarnished just from sitting around too long? Esp where you have saltwater conditions in the surrounding air! This switch actually & electronically is wired in REVERSE so that when switched to the ON position the wired contacts are OPEN thus letting the Ignition Coil fire for SPARK. When switched to the OFF position the wired contacts are now CLOSED thus connecting (or switching) the "Control Board" logic voltage signal (usually anywhere from +3 to +12 VDC upon start-up) to GROUND - thus cutting the RUN voltage to the Ignition Coil fire - as in SHUTDOWN. On some model designs there also may be a separate IDLE CONTROL SWITCH and POWER REGULATOR BOARD for better POWER LOAD self-regulation depending on constant variable loads placed on the Genset as related to the work-site demands. If there is NO VOLTAGE OUTPUT but yet good engine RPM function - then I would look at this part first and then #8.
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing that! If equipped with one - This anti-dieseling solenoid has to work properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Carb Float stuck in the CLOSED position not letting gas into the Main Jet? If the Genset is brand brand new and truly has never been fired up even once and used, such as like that of 2-3 years or longer from actual date of purchase, then that Carb Float may very well be stuck CLOSED. Worse yet - the Main Jet may be clogged with MICRO DEBRIS coming down from the new gas tank - esp if there is NO FUEL FILTER present in the fuel line. I've heard of this happening more then just a few times myself. You might try and TAP CAREFULLY on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is that colored WIRE (see #5 again) at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you WILL damage it! If this dislodges the stuck Carb Float to the point that the Genset now wants to run to some degree better then before, but not fully 100% better and to spec - then you definitely still have Carb Float and/or fuel delivery related issues, and/or MICRO DEBRIS in the Carb Bowl or Main Jet inlet. If the Genset begins to run great - as it should - and continues to do so - then your NO FUEL or NO RUN problem is solved! I would still take the Carb Bowl off and clean out the whole Assy there just as an added precaution anyway as you just never know. When Gensets are truly needed in an emergency condition you just don't want to RISK anything!! NEVER FORCE ANYTHING EITHER!! It's possibly that you might have to loosen slightly, and/or totally remove the Float Bowl (usually 2 screws) to see if indeed any gas is getting inside to the Float at all. If gas comes out readily but still no gas is getting into the Main Jet and intake then you purely have a DIRTY CARB issue and nothing more! If you're not smelling gas through the air filter box then you are FUEL STARVED. ALSO - Many a brand new shipped Genset will have some kind of NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the tank itself or even in the rubber gas line (I've heard of this problem before, and seen this myself 100's of times with cheaper rubber hoses). That is why an added in-line FUEL FILTER (if your Genset has none) is SO important!! Usually a common $2-3 item at any auto parts store. Once gas is added to the tank all this micro debris is set free to enter into the CARB FLOAT BOWL, and that is where Carb problems will start - even with a "brand new" never run before Genset!!
Posted on Sep 10, 2008
Anonymous
SOURCE: headlights always blow out
I took mine in for this same problem. They told me the alternator was charging "too good" and they replaced it. Sounded fishy to me, but the alternator was under warranty at the time so it was a free fix. In any case after that my headlights never blew out again.
Posted on Sep 23, 2008
Anonymous
SOURCE: what size generator, watts, doe's it take to start AC unit 57915.531 ?
a 10000 due to the startup surge. also need start kits on any ac started by a generator.
Posted on Oct 10, 2008
tbrat44
  • 86 Answers
SOURCE: 04 yfz 450 wont start with electrical start
i have a 04 yfz 450 quad. the compression ratio like yours is extremely high. ive had my battery go bad and found that another battery other than factory would turn over the engine, but would not start. i paid the 100 dollars for the factory battery and it fired right up. because of the high compression you need a high cranking battery.
Posted on May 07, 2009
Anonymous
SOURCE: Sony Vaio wont start up
slap the **** out of him and then **** his girlfriend. and tell his mum to buy you a new laptop but you may have to **** her for a new one
Posted on Jul 22, 2009
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
4500 running watts 5625 starting watts
http://www.manualowl.com/p/Homelite/HGCA4500/Manual/185973
Mar 23, 2015 | Watts Electrical Supplies
I have a champion 6500 watt generator......its getting very hard to start. Ive been told because im not drawing enough power its gettin carbonated up......how do i fix this
Install a new spark plug first. Then I would do a good carburetor cleaning. These two things usually fix most starting problems.
Now if it is in a cold environment it may simply not being choked enough.
Feb 04, 2015 | Electrical Supplies
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
Homelite 2500 pwer generator won't keep running when cord put into it
The load may be too much for the generator. Remember that some loads, especially those with motors driving a machine (like air compressors) require much higher startup power than what is listed on the nameplate. General rule of thumb is to allow 2-3 times nameplate rating for generator rating. For example. If your air conditioner is rated as 800 watts, then you would want a genreator AT LEAST 2400 watts to start and run the compressor.
Nov 30, 2009 | Electrical Supplies
My standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Jul 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Garden Logo
291 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
