SOURCE: lost remote
Fairly easy and resourceful fix for this. Spent the past hour on the net looking, and no one had any info. So, we post here!
Our remote was lost, and were in the same unable to use the input port situation on our Durabrand BH1304D. Tried 3 universal remotes with no luck. However--- we are back in business now, Houston!
My fix-- grab a DirectTV remote (we had a white one-- RC 32 is the model). It's compatible with this 13" Durabrand TV, and most people a neighbor probably have one!
To program it to the TV (at least in our case), you have to slide the top switch to TV, then hold and press MUTE and SELECT until the green light flashes twice under the TV switch. Then press numbers 11034 and the light should flash twice again. Ta-da! Should be in business. We were!
The input button also worked as is, no need for the other step listed in the remote manual. But if your TV is changing channels and volume, but no input button, quick easy fix there too apparently. Didn't have to use it, but the input button can be activated or deactivated as needed. Simply hld SELECT and MUTE down again, the hit 960 on the keypad. That should be the activate/deactivate code per the manual.
Hope this helps someone, as the durabrand remote situation stinks, but thanks to the power of internet and users like us, there's now a solution in your reach! :)
Steve
karaokestl.com
SOURCE: Sylvania TV stuck in Game mode remote no longer works
just go to channel setup and add/delete channel, it should exit the game mode. then do nothing unti the add/delete option exits the bottom of the screen.
SOURCE: how to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
