Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code E 68 - Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Oct 29, 2010
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611843
Points
4917
A button is stuck and it needs to be unstuck. Enter key test mode during the diagnostic test mode to determine which keys is stuck.
Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control.
The buzzer sounds then immediately turn the cycle selector knob counterclockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds then the control enters diagnostic mode. The buzzer sounds 3 times and the LEDs flash.
Turn the cycle selector knob clockwise the second position from the top. The drive motor runs and the heat source turns error code E 68 - 7db95d8.jpgimg src="/uploads/images/7db95d8.jpg" alt="7db95d8.jpg" class="h_mi" />
The buttons can now be tested. Press each button and the corresponding LEDs turn on. You should be able to find which button is stuck. The Options and Select buttons turn on the same set of LEDs and also the Cancel and Start/Pause buttons.
Access the control and unstuck the button. Disconnect power and remove the top panel by removing the screws attaching it to the rear of the dryer. Slid the panel rearward and lift it off the cabinet. The screws attaching the console to the cabinet are exposed. Remove the screws and disconnect the wire harnesses then remove the console. The control can now be removed and the buttons are exposed. Unstuck or clean the stuck button contacts. It is recommended to clean all other button contacts to prevent the recurrence of the same problem in the near future.
Rheem furnace error code 68
Rheem furnace error code 68 is a mechanical relay system which signals the blower motor to stop because it has not received a signal from the thermocouple.
Jul 20, 2022
Rheem furnace error code 68 - HVAC Contractors
Motor Power And Communications Issues (Fault Code "68")
ManualsLib https://www.manualslib.com > Rheem-96v-Series
Motor Power And Communications Issues (Fault Code "68"); Line Voltage And Low Voltage Connections To The Communicating Motor - Illustrations - Rheem 96V Series ...
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 • Dryers
ERROR CODE:E~AC
Hello, did you this error? I'm getting the same one :(
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
2helpful
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
