I can't find the serial number on my Husqvarna 455 rancher chain saw so i can register it. I have looked all over the outside of the saw but have seen nothing that says serial number.
We just bought one in Feb and I found it by the handle on a black metal plate starts with the year and followed by numbersWe just bought one in Feb and I found it by the handle on a black metal plate starts with the year and followed by numbers
You can't post conmments that contain an email address.
not sure if the 455 rancher is the exact same as my rancher but when the oil feed on my saw seems slow i remove the chain and bar and clean the chain grove. pay special attention to the end that is near the motor there are a couple of places that allow the oil to flow from the saw body to the chain groove and then subsequently to the chain
you should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
Go to http://www.milacalawn.com/parts.asp and look for the bolt that hold the brake.usually the bolt is located in the chain plate that has a large groove in order to adjust the chain.
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw): http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf An excerpt from page 38 of the above OM follows (forcing it may render it inoperative): Adjustment of the oil pump Adjustments are made by turning the screw using a screwdriver or combination spanner. The machine is supplied from the factory with the screw set to position 2. Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow. Recommended settings: • Bar 13"-15": Position 1 (full CW) • Bar 15"-18": Position 2 (center) • Bar 18"-20": Position (full CCW) These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step. WARNING! The engine must be stopped when making adjustments. All OMs and IPLs can be found here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarificationhttp://www.husqvarna.com/us/homeowner/support/customer-support/) 15 = week produced – March 00198 = 198th unit Husky produced that week If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
A Husqvarva IPL for a 455 Rancher 2005-01, follows (may not be your saw): http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501036.pdf See print "A" (clutch cover) pn 537 28 64-01 & pn 503 21 70-10, if missing or loose these may cause your problem. If not an inspection of the parts beneath may disclose the defect.
If the bar is what can be moved pn 537 28 65-01 or 537 28 66-01 may be stripped. After I determined what parts need replacement, I would contact a local Husky Dealer. They may have these parts on hand and if not ordering through them should save you shipping and handling fees.
If your saw was not manufactured between Jan 2005 and Mar 2005 you can find your IPL here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarificationhttp://www.husqvarna.com/us/homeowner/support/customer-support/) 15 = week produced – March 00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
It sounds like the chain is too tight. Loosen up the tension on the chain by turning the tensioning screw located on the end of the saw where the bar goes out.
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw): http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well: Reset Chain Brake by Dolfoff Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH Lou
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
