Got ot the link below page 67-68 will tell you how to set the alarm. Alarm clock Open the alarm clock tab. To set an alarm, select Options > Set alarm. When an alarm is active, is displayed. To switch off the alarm, select Stop, or to stop the alarm for 5 minutes, select Snooze. If the alarm time is reached while the device is switched off, the device switches itself on and starts sounding the alarm tone. If you select Stop, the device asks whether you want to activate the device for calls. Select No to switch off the device or Yes to make and receive calls. Do not select Yes when wireless To change the alarm time, select Options > Reset alarm.
http://nds1.nokia.com/phones/files/guides/Nokia_E51_UG_en.pdf
Or
phone use may cause interference or danger.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
