Turn off the computer and when you restart it keep tapping the key F2 on the top left of the keyboard.
A BIOS screen should come up. If you see the lines on the screen at that time then yes its a hardware issue. If not then your video card drivers might be faulty and you can re-install them.
Thanks
If this was helpful, then kindly rate me.
Testimonial: "WOW !! Almost instant response, easy to follow instruction. The bad news, it is hardware. Next, search for right part. Thank you for your help."
Typically, that does indicate a problem with the screen or a connection problem with the wiring between the system board and the display. Check Dell's web site with your service tag if you are not sure about warranty coverage.
Always get pricing ahead of time before sending in a unit for repair. With screens, often it is not worth repairing them depending on the age of the unit.
Testimonial: "Thanks, plan to repair, like this one. Thanks"
