Sony VAIO VGN-CR220E/P Notebook Logo
Posted on Jun 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop will not boot, Sony Vaio VGN CR220E, The computer turns on, but neither the monitor, nor the hard drive kick on. I think it may be a hardware problem. I've tried connecting another monitor to no avail. It seems like my hard drive has failed, but i have no way to tell, nor do i know how to fix it. My caps lock, num lock and scroll lock leds blink and go out, it doesn't beep, just clunks and stays in what appears to be sleep mode with no noise from the hard drive
Bill Boyd
Level 3:
Top Expert:
  • Sony Master 53,816 Answers
  • Posted on Jun 08, 2017
Bill Boyd
Sony Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11935138
Points
172802
Most likely a failed hard drive and the fix is a new one
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Dec 07, 2008
SOURCE: need driver for sony vaio VGN-CR220E built in web cam, motion eye
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
There u go, all availble files for Vaio VGN-CR220E and Vista
Good luck
Anonymous
  • 601 Answers
  • Posted on Jul 10, 2009
SOURCE: i need drivers for sony vaio vgn cr220e for
You can get the drivers from the sony offical site.
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER&TC=b2b
Thanks
Smith
Anonymous
  • 558 Answers
  • Posted on Nov 11, 2009
SOURCE: Laptop will not boot, Sony Vaio VGN CR220E, lights
I need you to try a few things.First remove the battery,memory no power whatsoever.Press and hold the power button for twenty seconds.Replace the memory then the ac cord and try again.Remove the power only this time and press and hold the power button again.Now replace the battery and the power adapter.Power up and you should work if not you will need to replace the motherboard.
Good Luck
Anonymous
  • 5 Answers
  • Posted on Feb 14, 2010
SOURCE: Sony Vaio VGN-NW26M Touch Pad won't scroll
reinstall the driver
archaeology
Archaeology
  • 662 Answers
  • Posted on May 14, 2011
SOURCE: my sony vaio vgn-cr220E was
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
Flash Loader Utility incompatible
If FLU is referring to USB drives, then try adjusting the boot menu order in BIOS and make the hard drive 1st boot.
How to get in BIOS setting to change "boot from CD" so that i can install my window 7
Most computers are different. For this laptop try these,
Sony - VAIO, PCG-Series, VGN-SeriesPress F1, F2 or F3 after turning on the computer
If you find that this is information was helpful to you, please rate me andleave a comment as this will encourage me to do more free work for you andothers. Thank you for using FixYA!
Best regards,
Junior
I have a Sony VGN-CR220E. It would turn on but all I see is a black screen. The green light on the bottom lights up but all the rest won't light up anymore especially the 3rd light that would blink,...
One thing to try is if you can, connect an external monitor to the computer. Turn it off and then back on with the external monitor on. If video on the external monitor then the problem is with the laptop monitor most likely the FL inverter or the lcd itself. If no external video, it is most likely a motherboard problem.
2helpful
2answers
Laptop will not boot, Sony Vaio VGN CR220E, lights come on, don't hear the Hard drive start up, however. I get the clunks from the CD drive, but that's all.
Such problems happen when you have either faulty RAM or faulty Mother Board. Repairing MotherBoard Chip is a costly affair but replacing RAM is convenient and most probable solution.
With Regards,
Ankit
Sony VAIO® CR VGN-CR220E system crashed can Vista be re-installed
Yes there is, but you must know the correct combination of keys to press on boot up.
3helpful
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Problem in hardware in sony vaio VGN-CR220E laptop computer
It should power on when plugged in, even if the battery is pulled out of the laptop.Try holding the power button down for 10 seconds to see if it boots up when its plugged in.
Sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
2answers
Dear I have a sony vaio vgn-cr220e laptop, whith a hard drive of 200 GB. I would like to replace by other hard drive of more capacity (about 500Gb o 1TB). Please, suggest to me what model of drive i have...
you need a Serial ATA hard drive, and you may have a limit to how big of a hard drive you can go to.
Go to your local computer supply store and tell them what you need,,and they will sell you a compatible unit.
As to what type of drives to buy,,,,there are many types of drives,,and many opinions,,get the highest spin rate is all i would suggest.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
