HP OfficeJet Pro k550 Printer Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our HP OfficeJet k550n is a network printer. When attempting to print from a Lenovo laptop on the network, it locks up the main computer on the network. The only fix has been to delete the printer and reinstall it with HP's latest driver. It might work for a few days and then it happens again.
Level 3:
  • HP Master 7,733 Answers
  • Posted on Oct 28, 2010
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1864782
Points
21487
Follow these steps to add the HP product to the list of devices.
  1. On the Windows taskbar, click the Windows icon (Our HP OfficeJet k550n is a network printer. When - c01319360.gif ), and then click All Programs .
  2. Click the HP folder.
  3. Click the Printers folder.
  4. Click Add a Device .
  5. Follow the on-screen instructions to complete the process.
Help! Our Dell Inspiron 1521 laptop (service tag# 28D58F1) stopped printing. It was printing through our wireless network to our main computer with printer attached with no problems and then one day we...
There are several things to look for, but here are the first things to check:
  1. Is the printer plugged in and turned on?
  2. Can you print a test page from the main computer to the printer? If not, check what is in the queue to print on the main computer. Delete (Cancel) any print jobs in there that are not printing.
  3. Is the printer on the main computer marked as shared, if not, mark the printer as shared.
  4. Look at the print queue on the Inspiron laptop, if there are jobs stuck in there, delete (cancel) any stuck print jobs from the laptop and attempt to print a test page from it's printer properties by right-clicking on its icon in the control panel and clicking Print Test Page.
  5. If none of the above has revealed the problem...
    1. Remove the printer from the laptop by right clicking on its icon and choosing to remove the printer.
    2. Click on Add Printer and attempt to add the printer back to the laptop by following the instructions that come up. If the printer is not located, make sure your wireless network is running and that you are able to connect wirelessly with both the main computer and the laptop.
      1. Make sure that you are on the same Workgroup or HomeGroup
        (right click on Computer (or My Computer, or This PC) in your file explorer and choose properties to see your Workgroup or Homegroup information) in any case, both computers must be on the same network).
1helpful
3answers
How do I get the HP 6500 to print wirelessly?
For installing a wireless printer on Windows XP, wireless router is an essential device. Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network. Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port. To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting. This will allow the operating system to recognize the availability of a wireless printer. Now, click the Start button, go to Devices and Printers, select Add a Printer option. Click the second option- Add a network, wireless or Bluetooth printer. The computer will search for available printer and reflect it on the screen. Click Finish; and the printer is ready to begin the printing process. get more detail for Wireless Printer Setup. Hope this helps you.
Thanks
Michel Smith
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
1helpful
I can print from main computer, but are now unable to print from wireless laptop, which I could 2 week ago
assuming that your printer is physically connected to your main computer, and that your laptop is wirelessly networked with your main computer,
then you need to have the main computer on as you attempt to print from your laptop
Shared printer printing blurry
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf29
5helpful
2answers
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
1helpful
2answers
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Oficejet v40xi only prints partial documents then "disconnects"
XP the virus magnet where anything can happen bad, and DOES !
why run 15year old OS.? why not upgrade.?
The Lenovo stinkpad. (was IBM)
why not move the printer to another PC, ? to prove printers bad
is that hard?
even plugged in to any LAPTOP, say with W10
v40xi , as old as 2003, is yours that old?
was even run on old windows 98 back when.
but has HP support up to windows 8.1
try printer on win7 win 8.
is the way to do this, using the correct driver. from HP.com
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
k24674
Grand Canyon Tech
Grand Canyon Tech
