Samsung Digimax i5 Digital Camera Logo
Woody J Hiatt Posted on Jun 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Charger red lite flashing. Camera comes on for one second and shuts off
I5 Working ok for ten pictures and later in the day wouldn't stay on. So put it in charger and red light on on cable is flashing. Battery voltage 3.9 volts. Camera won't cut on to download pics either.
Anonymous
Level 2:
Novelist:
  • Expert 103 Answers
  • Posted on Dec 10, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
103
Questions
0
Helped
39290
Points
177
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
3helpful
2answers
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
3helpful
2answers
Does not charge,red flashing light on charger
Take a nine volt battery and put + to + and - to - for ten seconds and try to charge again if it does not work then you need a new battery.
Hi i have a Casio Exilim 8.1 digital camera, ive had it about a year and its worked fine but ive just put it on charge and on the charger thers a red flashing light, were normally the red light doesnt...
The cradle is defective.  Casio replaced the first one of mine for free then they told me to sit and spin when the second one broke 8 months later.  I had only used the camera ~ 10 times.  So, I went to a big box electonic store (Best Buy) and bought a Digipower travel charger.  It charged the battery up just fine.  I also bought a Dynex Memory Card Reader/Writer to transfer the photos to  my computer.  Good luck.  The defective cradle is a known problem that Casio is refusing to correct.
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
42helpful
10answers
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 • Cameras
4answers
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Battery problem or camera problem?
A new battery should help you to solve this problem.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
