After I try to turn tv on I'll get 5 red blinking lights, then pause, then 3 lights, then long pause, then 5 lights, pause, 5 lights, pause .......Thank you for you respond.
My tv will not turn on and no lights will turn on either. There was no warning at all.My tv will not turn on and no lights will turn on either. There was no warning at all.
You can't post conmments that contain an email address.
The standby light should be flashing in a sequence of a number of flashes followed by a pause then another sequence...
Please post that count here as that is a diagnostic code to indicate the circuit that has the problem. The set goes into shutdown flashing this code to prevent further damage to the set.
Once the code is posted, I can provide you the circuit and probable failing parts.
Dan
Hello, I have a similar problem with my sony tv KV-32FS120 the tv was shut down and when my dad went to power it up, it wouldn't turn on. The TV blinks 9 times. can you please tell me what the problem could be and where and give me some diagnostic hints and where I can find those parts. I would really appreciate your help. Thank you very much
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
TV will not turn on. Stand By red light blinks a constant sequence with no pause.
