SOURCE: Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
SOURCE: what does f8 on dacor self cleaning oven mean
HI. This will generally be an issue with either the wiring at the door switch mechanism, or the door switch itself. Check the door lock switches and wiring. If the wiring is connected well, this will lead to a failed door lock switch mechanism. Use my procedure below to confirm switch failure.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Once access is gained, set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use cuation when testing.
Testimonial: "thank you very helpful "
SOURCE: dacor oven self cleaning instructions?
Go to link below and get the manual for your model. http://tv.manualsonline.com/ex/thread/view/idThread/1185347
SOURCE: Dacor error codes
I had the error code F 0.
I unplugged it and plugged it back in.
This fixed my problem.
Here is a link to Dacor's error codes.
http://www.repairclinic.com/0078.asp#Dacor
