Question about Jura Capresso Impressa F9 Espresso Machine
The tray will not fit back in the machine, its jammed and I don't know how to reset the machine on a Jura F9
  • 33 Answers
This happens when the try is removed before the brewing unit resets fully.
To fix is easy.
  • Remove tray,
  • Lift off grinds bin from the tray
  • Return tray to the machine with out the grind bin
Now you need to reset the brewing unit this is done by either
  • Starting a rinse cycle
  • Powering off and then on
Once you have don that return the grinds bin to the tray and it will go in.
Posted on Oct 31, 2010
    Problem Solver:
  • 6 Answers
You might have made a cup of coffee after dumping the grounds and forgot to put the grounds bucket onto the tray. Ask me how I know! In any case, the previous solution won't work.
It's easy to fix though. Pull out the tray and you will see the mechanism hanging down preventing the grounds bucket from sliding in. Take the bucket and tilt it in and around the mechanism. Then hold it up while you slide the tray in under it. Turn on the machine and it will reset. Enjoy!
Posted on Jan 24, 2013
SOURCE:
Can't push the tray in - the piece is down in the back and won't come up
It is probably because the brewing unit has not stopped in the correct at rest position. I'm not familiar with your brand but sometimes if you remove the bin from the tray you can slip the bare tray back in under the brewing unit enough to activate the machine so it can reset itself.
Sep 29, 2014 | Jura Capresso Impressa F9 Espresso Machine
Cannot get tray to go back in after emptying grounds
Unplug machine, wait a minute or so, plug back in while pushing the tray in as far as possible. It makes some noise as it resets and moves parts around inside. The tray then goes in easily.
May 04, 2011 | Jura Capresso Impressa F9 Espresso Machine
I have a Jura Impressa C5. My drip tray mechanism is broken because I pulled out the tray while it was still operating, and a piece of plastic of about 7.5cm x 17 cm (3 in x 7 in approx) came off and...
This is the used grounds blade that makes room in the used grounds container. This is fixed to the brewing unit, and can not be reassembled without opening the machine. If you make sure to check your grounds container often, you really don`t need to put this blade back. Just make sure that the container doesn`t overfill.
Apr 27, 2011 | Jura Capresso IMPRESSA F60
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
Cannot insert the tray all the way
Remove tray and replace leaving out the used grounds box. Restarting the machine resets the brew unit and the tray with coffee grounds box can now enter fully
Nov 20, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura F9-inside part fell off while pulling the tray. Cannot fix.
Kris I have this same problem. Did you figure out how to replace the flap or did you have to take it in for repair.
Does anyone else know how to replace this plastic flap?
Feb 24, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
The cleaning cycle is not complete (Jura F9)
This indicates that the Flowmeter is either dirty or defective, it sends incorrect messages back to the electroninc board about the waterflow. It`s located on the left side (seen from behind) as a white sircular box with 2 hoses and an electrical contact on top of the lid.
May 16, 2009 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Impressa F9 Espresso Machine Logo
11,277 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
