That depends on the connections your Sony TV has. If it has only the coaxial connector (the cable looks like this: http://www.w-l-t.org/Pix/Coax%20w-F%20connector.jpg), then you'll connect a VCR to that, and then the blu-ray player to the connections on the VCR using the composite cables (yellow, red, white). Switch the VCR to channel "L" or "Line" (usually below channel 2), and it should pass the video through to the television. Of course, if the TV itself has the yellow, white, and red connectors, you should just be able to connect the Blu-ray directly into that.
Also, it may be possible to connect your cable box as an intermediary like I just described with the VCR, depending on your model of cable box.
