Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
The toner was not removed prior to moving the copier
