SOURCE: GeForce 8600 GT 256MB DDR3 PCI Express Graphics Card doesn't work
contact the shop / place you purchased it from and they should be able to give you info of where to send it and what to do - they should have a section on there website where you can go through the return process and you will most likely need to get an RMA number to authorise the return / replacement.
SOURCE: screen all hazzy letters hard to read
Pull out the graphics card & RAM chips. Give their contact points a good cleaning and replace hem. Also check to see that all cables are snug tight. Finally remove the Monitor cord fro its slot at the back of the CPU and remove all dust and check if any pins are loose. See that the monitor plug is firmly placed..................sodeep
SOURCE: my graphics card is xfx 8600 gts my card problem
well my experiance with that card having a similar issue. i tried switch cables resetting the monitor to factory settings reinstalled drivers removed the card reinserted it. called xfx and it ended up being bad they rma it and got my new one and it worked fine then. hope this helps
Its a GPU problem.
It can be overcome by doing reflow technique.
You
need to do following.
1. Uncover ur PC casing
2. Locate the
nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU
fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get
scrambled display/wavy screen, but wait for 5 minutes.
7. Press
reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10.
Connect the power supply pin back as it is.
11. Power on ur PC.
thats
all.
Removal of fan power, makes the GPU to get high heat, it a
reflow technique.
Remember, not to touch the GPU portion (heat sink),
as it may be in higher temperature.
Try this, it works most.
Clarifications:
[email protected]
SOURCE: when i boot up,get 1
the beeps are post during
post the very first work is done by the ram,all the memory in the ram is first
transferred to the hard disk,and remains active untill turned off. make sure
that your RAM is securely seated One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA the leads from your ((motherboard
to your hard drive)) make sure they have a secure connection and are not
faulty or just replace them there probably old and faulty
make
sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have
secure connections and are not faulty even the electic extensions or just
replace them they could be faulty a computer needs its connections to continue
its cycle and have an end so any faulty leads will end up with a computer error
hope
this helps
make sure
make
hope
this helps
