IMSI Micro Cookbook 5.0 Full Version for PC Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can micro cookbook 5.0 be adapted to run in Win 7?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
485
Points
Anonymous
Level 3:
  • Master 532 Answers
  • Posted on Oct 27, 2010
Anonymous
Master
Level 3:
Answers
532
Questions
0
Helped
172205
Points
1592
Use the compatibility mode for the program. This will allow you to run it as if you had an older version of Windows. If it ran under Windows XP, this should work.
Right click on the icon and select Troubleshoot compatibility. The compatibility wizard will start and make a determination for your system.
Win 7 driver for Linksys wpc54gx
Linksys has a page for this device.
You need to ask them for drives
I assume they will tell you it is not supported in Win 7
Linksys Support
2answers
Kingston microsd using usb adapter is not recognized on laptop (vista premium 32bit) and on hp desktop (win 7)
Have you checked the drivers for the usb adapter. plug it in and go to my devises and up date driver see if that fixed it. vista software may have a problem as they are not updating there software files. but win7 is fine has same filing as xp.
2helpful
6answers
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
All you have to do is:
Step One:
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
How do I upload pictures from my Samsung Strive onto my Gateway laptop comuter.
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter.
If your Gateway laptop has a SD card reader:
5. Put the adapter into there.6. Transfer the pictures to you computer. Done!
If your laptop doesn't have a SD card reader:
5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
Best of luck, Juseppi
1helpful
3answers
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
2answers
Belkin n adaptor will not work with windows 7
Download the Drivers For Vista2_bing.gif 64 Bit From
www.belkin.com/support
Step 1 : Right Click on the exe File And select Properties
Step 2 : Click The Compatibility Tab
Step 3 : Select Run this Program in compatibity mode For Win Vista SP12_bing.gif
Step 4 : Click Apply
Step 5 : Now try to install it
I need a vista compatible driver for an IOgear gbu311 bluetooth wireless adapter
GBU311 does not have a Vista driver. Because it could only support the Win 2000, Win ME, 98SE, and XP. It does not support Win Vista and later versions.
If you wish to have a Bluetooth adapter that is compatible with Vista and Windows 7, you need to have the GBU421 Bluetooth 2.1 USB Micro Adapter. Here, check the link:
http://www.iogear.com/product/GBU421/
Thank you and good luck!
Top IMSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
