You should stop recording new ones to prevent the old ones from being overwritten. If your digital recorder has a memory card, take it out and insert it to your computer with a card reader. If the device has built-in memory, just connect it to your PC directly. On your computer, you need a video/audio recovery program. Fine one, install and run it. The software will help you scan lost audio files from your recorder, then it'll show you what it's found. Choose the files you want and hit the "Recover" button to start recovery process.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
You can recoverlost photos,videos from memory card or memory stick of your camcorder withthis 1. Do not save any new photos and videos into the memory card or memory stick. 2. Connect the memory card or memory stick with computer. You should see itshown as a drive letter (like H:) in My Computer. 3. Download memorystick recovery software, recommended one is Tenorshare Data Recovery(simply because i was using it and it worked) http://www.any-data-recovery.com/product/datarecoverystandard.htm 4. Install and open the program, select your memory drive, and click 'Start'button to start scanning process which will find your lost photos and videos.
you can use card recovery software that helped me before 1. Do not save any new file to memory card. 2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer. 3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked) http://www.asoftech.com/adr/ 4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your deleted files.
Formart the card, either from the camera, "if it offers the option, most do" or if you have a memory card reader in a desktop or laptop, that is what it sounds like to m, best of luck Gym
According to the samsung website "
Samsung camcorders manufactured in 2004 and later can be used with memory sticks up to 1GB. Anything over 1GB is not guaranteed to work. "
I have the same problem. Video works fine on my 256MB card but not on my 4GB or 8GB cards. It would be nice to know if anyone has success with a particular card >1GB.
You can record video with audio onto the Memory Card. Follow the instructions below.
Recording moving pictures onto a MEMORY CARD
1. Insert a Memory Card into the slot on the camcorder.
2. Set the mode switch to MEMORY CARD position.
3. Set the power switch to CAMERA mode.
4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4.
* You can record 10 ~ 20 seconds continuously.
* You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button.
5. Press the START/STOP button to stop the recording.
Notes:
* Moving images that you recorded are saved in *.asf file format on the Memory Card.
* The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape.
* The sound is recorded in mono.
* The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter.
* Don't insert or eject a tape during Memory card recording as it may record noise.
* Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
