I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it
will not pick up many European radio stations. This is due to the fact
that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Thank you it is work
