Garmin nuvi 250 GPS Receiver Logo
Anonymous Posted on Oct 27, 2010
Need to change the time on my nuvi how do i do it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
133
Points
I forgot the pin code for the sat nat snooper s2000.
how cwn i change ?
perdue40
Level 3:
  • Garmin Master 589 Answers
  • Posted on Oct 27, 2010
perdue40
Garmin Master
Level 3:
Answers
589
Questions
0
Helped
122124
Points
1317
The time should be automatic unless you are in a different time zone....
Not sure where you are located but here is the way to it to put your time zone
Tools....Settings.....Time.... ( Press ) Time Zone enter your zone there the proper time will appear
1helpful
I have garmin nuvi760 gps when ever I hook it up in my car fuse in car charger cable blown up, I changed the fuse several time ,it does the same thing,it takes 3amp 250V fuse.I realy need help.
You need to determine if it is a charger problem or a problem in the Nuvi.
If you have the AC wall charger, plug that into your Nuvi. If the unit boots normally, then you can discount that there is a problem with the Nuvi. Does the Nuvi power up on its own internal battery with the charger disconnected? When you change the fuse and it blows, is the charger plugged into the Nuvi?
Try changing the fuse and powering up the charger without it being plugged into the Nuvi. If the fuse still blows, then the fault is with the charger. Please also be aware that the charger converts +12VDC from the car battery to +5VDC to power the Nuvi. Some chargers can fail and provide +12VDC directly to the Nuvi. This can damage the Nuvi and will certainly blow the fuse.
tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
I wish to erase phone numbers, transferred from my cell phone to my Garmin 265WT when pairing the phone to the Garmin. These phone numbers came from my cell phone and I cannot remember who is associated...
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
1helpful
15helpful
2answers
Change the language on the garmin nuvi 1300
I have just bought a garmin nuvi 1300 and when turned it on the language is german or dutch. We need english but cannot figure out how to change to that seleciton. Help??
I have a garmin nuvi 265w and when i connect via bluetooth to my BBerry curve the garmin turns off and on occasionally (usually at a critical point in my trip or during a phone call !). i have the current...
Also, a Nuvi that is turning off and on is symptomatic of having corrupt firmware.
I hope that helps.
Need to add and delite numbers to phonebook
I hope that helps.
Garmin 265wt. How do you delete duplicate # fm phonebook?
I hope that helps.
Nuvi 200W series: need language change
If you don't know foreing language displayed try follow that to change it to English:
- touch Tool icon
- touch upper left icon
- touch Down arrow 1 time
- touch upper ( of four) line
You'll find 3 buttons on the right Upper/Middle/Lower and 2 on the bottom
Depress Middle one, then using Up/Down arrows select *English and OK
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
