Belkin (F5D5231-4) Router Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop say's not conected-& conections are availabble---Now I've tried the unpluging thig & reset button too & windows help also---I don't think the router is sending a signal
Level 3:
  • Belkin Master 7,733 Answers
  • Posted on Oct 28, 2010
Belkin Master
Level 3:
Answers
7733
Questions
0
Helped
1865017
Points
21487
1helpful
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
1helpful
When trying to connect to the internet via cord, my laptop will say limited or no connectivity. I have restarted it and started all the applications that were disabled. i also have the wireless chip for...
On the right below task bar find network conection >>> open network conection
On Local Area Conection ( cord ) right click >> properties rolls down to Internet protocol (XP) or IPv4(WIN7) click properties >>> on general tab choose Obtain an IP address automatically >>> click OK >> OK
[email protected]
Hello there my name is Isaac and i bought the net book yestarday, i followed the steps to conect it to my home's wireless internet and i could get it conected, however, although the netbook says that is...
I have a similar problem when connecting to a new network with my laptop sometimes.
I would try two things:
-Restart your netbook and see if it will connect, sometimes that's all it needs
-"Reset" your wireless router. This does NOT mean hit the reset button to get rid of all settings, instead, just unplug it for ten seconds and plug it back in.
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
I have an older latitude laptop and the screen goes dark shortly after the computer is turned on. What do I need to do. It has window XP if that makes any difference. Thanx
try to conect external monitor to this laptop if there will be same issue then its vide card if not then LCD alsow cheack conection from motherboard to lcd and you could try bis test (at turned off laptop hold "D" and turn laptop on then relese all buttons) it will cheack LCD
2answers
Intel wm3945abg wireless dont conect
Try reset router to factory settings and start from scratch. Uninstall drivers for wirless card and reinstall...
HOW CAN I GET INTERNET CONECTION IN MY LAPTOP
I assume that you have loaded all the drivers for you laptop from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If you need the manual,
http://support.dell.com/support/edocs/systems/latd410/en/index.htm
The instructions for connecting to a wireless network is under the "wireless local area network" instructions.
1helpful
Wifi signal canot conect because of DNS problem
see pal.for this you do require ip address settings by that i mean ip address,subnet mask and default gateway.if you do have these settings then the dns address can be used for static ip address primary = 4.2.2.2 & secondary = 4.2.2.3
take care
1helpful
Dilnk 655 router conected i can connect through wireless on laptop but the desk top which is wired in from router is saying not conected to internet the network magic program says router is not conected...
try reconneccting the lan cable from your router to your main desktop, take it out for about 5 seconds then put it back in, a light should turn on around the port but check with the on screen details. this should fix it, if not you may need to set up a lan connection through thte network thing
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
