You can try with an automatic driver tool, yes of course, it could be installed manually, but to avoid the hassles, you better opt for a driver utility.
Download and install this software (Device Doctor Free). Once it's installed, run the program and click "Begin Scan", wait for few seconds until the scan completes and search the scan result for realtek, if so click it, the direct download page will open up, download and install the driver, that should work without any more hassles.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
I'm not sure where to exactly find it but I do know the driver in xp for this card is the Microsoft UAA function driver for high definition audio adi 1986. Google it and you should find the driver. The tough part is in the installation of the driver.
There are two tricks that you should know, save the driver to a disk before you uninstall SP3 as it will make youre Internet Explorer 8 no longer run. Because of this I would also suggest loading the .exe install file from Microsoft for Internet Explorer 8 onto a disk as well so that you may run Windows Update to reload SP3 when you are done.
Good luck and I hope this helps.
Toshiba Satellite A505 Drivers download link. Easy come
