HP skimps on power supplies, using a supply that has only a small margin of excess power.
This causes the supplies to run under stress too often.
Make sure any replacement supply has the correct physical configuration for your system and replace it with one that is capable of 50% more power than the original rating; the cost difference is likely to be minimal and in any case lower than an 'original HP' unit of the same power rating that has now failed.
It is possible that a failed mother board or hard drive is causing your problem but you are risking well under $50 (for an ~400 watt supply) and will be getting a superior unit.
eBay is a good source and you can seek a replacement using the Pavilion series name and then checking for your particular model number.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
