Question about Planar PT1510MX Monitor
PT1510MX monitor using GUNZE usb controller will not stay calibrated. I can replace it with another monitor and it works fine.
Calibration ?
To calibrate your printer you first calibrate your monitor with DisplayMate. Then you print the same DisplayMate test patterns and match them to the monitor by using the print driver controls.
Calibrating Your Printer with DisplayMate
Nov 20, 2015 | Office Equipment & Supplies
How do I calibrate my windows PC monitor?
To calibrate your screen you have to open the control panel by clicking on the start button then the control panel in the right collum. Type "calibrate display" into the search bar in the top right of the control panel window. Open the calibrator by clicking on "calibrate display color" you may have to have administrator permission to calibrate the screen. Then follow the instruction on the screen.
Oct 20, 2013 | Computers & Internet
Color calibration
All monitors have a brightness control. Click the menu button and from the on screen menu choose the brightness and set it to your liking. There should also be a contrast control and may or may not be a backlight control. All the user controlled setting are in the OSM.
Nov 27, 2009 | Computers & Internet
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Xbox 360 wireless controllers won't work
Try this:
hook them up using the play-and-charge usb cable
Then, disconnect the cable.
they should stay synchronized and worked fine after that.
Jun 16, 2009 | Microsoft Xbox 360 Controller
Error 2 on usb reading
I have also been experiencing the very frustrating "Error Code 2" issue half way thru the calibration process. Sometimes the error occurs during measurement No. 1; other times on the 2nd or 3rd measurement.
I am running a MacBookPro running OSX 10.7 (Lion Server) w/ Vmware Fusion v4.1.1 and Windows XP (SP2).
After experiencing over a dozen of failed attempts to calibrate, I started to tweak the Windows setup.
I found out after some experimentation that the issue is not so much the Alpine Imprint S/W, but much so with the USB/Serial interface hardware. The S/W has issues with error recovery, which forces the user to close and restart the application if an exception is encountered...but if the exception can be avoided in the first hand, it runs fine!
Would suggest to try the following tweaks to address the Error Code 2 issue:
(1) If using Vmware Fusion, ensure that the USB/Serial is connected. On the VMWare Fusion menu, select Virtual Machine->USB & Bluetooth->Connect Future Devices USB<->Serial. Ensure this is connected first before launching the Alpine Imprint Sound Manger (v2.10) application;
(2) The USB cable that comes with the calibration kit is quite long and I am not sure the shielding is that good. So try to straighten the cable out and not allow it to coil when connecting to laptop; this should reduce any potential interference and signal degenerating issues;
(3) Within XP, open up Control Panel->Administrative Tools->Computer Management->Device Manager, locate under "Ports" the corresponding port that the USB<->Serial interface emulates. Usually this is USB Serial Port (COM3).
Open up the Port Settings under its properties menu.Apply the following override settings:
Bits per second = 921,600 (or 115,200 is fine as well)Parity=EvenFlow Control=Hardware
Click "Advanced" button and override the following settings:Minimum Read Timeout (msec) = 10,000Minimum Write Timeou (msec) = 10,000
These simple override setting works like magic for me.I was able to complete all the 6 measures without a glitch.Hope this works for your setup as well.
PS. For subwoofer calibration I also found useful tuning down the gain beforehand on the amplifier. On the Alpine head unit, set the Subwoofer output level to very low (close to zero). On the amp-side (I am using 3 x Pioneer PRS-D4200F) set the gain switch anti-clockwise to a voltage slightly above 2V (do not over do this). Then after the calibration has completed, set it to just below 2V (clockwise rotation) to slightly elevate the output. The remaining subwoofer gain adjustment can now be done comfortably from the head unit's subwoofer output control.
Cheers,Damo
Jun 14, 2009 | Car Audio & Video
Adjusting length of time OSD stays on screen
in the menu is a timeout function, as long as your making a movement choice you should be able to find it. if nothing else go up and down until you locate it.
Apr 25, 2008 | Computers & Internet
Calibration of monitor
Here's the tip I used years ago on CRT's suffering this same fate.
Take one of your printed photo's and hold it next to the screen (with the same photo on it running in whatever software you want to print from)
Now using the monitors controls, make the monitor look like your photo that you have printed.
Nice and dark now like the photo, good =)
Now adjust the software to what you want it to look like when printed.
Looking good so far..ok
Save those settings in the program. then re adjust the monitor back to how you want it to look normally (as it was before basically)
Not the ideal soloution, but it works and it's free.
Apr 15, 2008 | HP f1905 19" Flat Panel LCD Monitor
Calibrator talk doesn't see monitor on mac
did you verify that the USB port is active and the cable is working? Check under the Apple menu for "about this mac" then click on more info. Click on USB to see a list of active USP devices. If the Barco is connecting it will show up in the list. May not say Barco, it may say unknown device but it lets you see that the cable and port are working. If not replace them or try it on another computer. If they are working then the Calibrator Talk software may be configured wrong, have you contacted Barco? They have a troubleshooting area on the web site.
Mar 28, 2008 | Barco Personal Calibrator V 21 in.CRT...
OSD locked out
hello you have Resolved ?
thanks andrea
Jan 25, 2008 | LaCie Electron 19" CRT Monitor
Planar PT1510MX Monitor Logo
149 people viewed this question
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
