The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
