I think you have your wires connected to wrong screw.
Wiring devices have screws that are color-coded as you noticed.
The Hot wire from breaker connects to dark colored screw(s).
The wires to Load (ceiling light-outdoor light) connect to brass screws.
If you need more help, add a comment at bottom and I will help further
I just connected two separated lamps on top off the switches following your explanation color screw to hot wire and it did not work, but my power went off what kind I do?
You need to test your wires using ordinary tester. Separate wires, turn on power. Do not untwist wires that are twisted together. Test each wire to bare ground wire. Tester lights up on hot wire. Hot wire goes to dark screw. Test some more. Test hot wire to other wires, including white wires that are twisted together .. test hot to all wires except bare ground. Tester lights up on neutral. Connect neutral to silver screw. If you do not have a neutral, then you do not have the wires needed for a receptacle. Assume that you have one wire left, that does not light up when testing, this should be the wire going to load (lights) ... this wire connects to brass screw.
BEWARE that the Leviton box instructions are misleading to a dangerous degree; they use the SAME box instructions for ALL their devices - including switched outlets. A box containing two single-pole switches has NO BUSINESS having instructions saying not to use it to replace switches that use 2 wires, or to wire in a neutral (!!) - because some of their OTHER products are Outlet combination devices. Only if your reading is careful or you are experienced, do you avoid a dangerous mistake. Incredible what Leviton did to save a penny...
