I open the top cover of my Pioneer Media Receiver PDP-R04U to dust of now it would not start.I tried to reset the box via remote control it did not start.I think I am doing someting wrong.Plasma standby light (red not blinking)Media Receiver ON Green light,standby (red not blinking) Prod.info:Pioneer Elite TV PDP-4340HD which comes with a Media Receiver PDP-RO4U and Remote control AXD1478 ....Thanks
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Pull up older posts.
The Media Receiver is the tuner/connector selector box.
If the top is removed the Media Box goes into shut down mode. It requires resetting by a Pioneer Authorised Service tool.
My initial response is "An S-Video Cable"... but I suspect this isn't the information you are seeking. You don't need to connect your receiver to the TV's video inputs UNLESS you want the receiver to switch between different video devices. PS - more information on what "my receiver" is would help too, also tell us what you're trying to accomplish as the end result. tell us about all the equipment you have, and how you would ultimately like to be able to control everything, and what inputs and outputs are on each device.
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
If you had power this set on with the back off it will not work without closing the switch again and entering serv mode and reactvating . Call pioneer customer serv to get info to reset the unit. Must have pioneer remote to do this reset.
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
i am also faced with the same problem
