SOUNDS LIKE YOU MAY NEED A SERVICE TECH.
IF THE CABLES ARE NOT RUNNING PROPERLY ON THE DRUMS IT WILL CAUSE THE PROBLEM YOU DESCRIBE. OR THE DOOR COULD BE CATCHING ON SOMETHING (DOOR JAB, TRIM ETC.) AS IT CLOSES.
I DON'T RECOMEND TRYING TO ADJUST THIS YOUSELF A PRO CAN DO IT IN ABOUT 10 MIN. IF YOU START MAKING ADJUSTMENT WOITHOUT KNOWING EXACTLY WHAT YOU ARE DOING YOU WILL PROBABLY JUST MAKE IT WORSE.
THE SERVICE CALL SHOULD BE $ 50.00 - $100.00
ALSO DON'T CALL A HANDYMAN ETC. ONLY A QUALIFIED DOOR REPAIR TECH.
HOPE THIS HELPS
Testimonial: "Thanks for the help! I actually tried adjusting the cable tension and it worked like a charm.... So far so good! Thanks again, Chifras"
