Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
Posted on Oct 26, 2010
Cuisinart grind and brew pot - door holding filter pops open during grinding/brewing.
Tom Howe
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Oct 31, 2010
Tom Howe
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
5137
Points
21
There is a little cover over a spring. The loops of the spring go inside the screw that holds the cover. The spring ends are against the wall and a small pin connected to the button on the side. Keeps the button locked. Cleaning out dried coffee in the are may help and pam spray may keep it from sticking.
  • bhilliar Feb 05, 2011
    Thank you very much. This was very helpful.
  • Anonymous Nov 08, 2021
    Tom, I have a similar problem with my Cuisinart burr coffee grinder model DBM -8 but new to this site Im having trouble posting my question. It seems the spring keeping the basket connected to to motor has come off. It sopped abruptly when it was grinding. I removed the bottom and this spring with a nub on the end fell out. Can you tell me how to reconnect it? Thanks. I need my coffee! I hope you’re still around.
Ed BATLEY
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 09, 2014
Ed BATLEY
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2832
Points
I have the grindn Brew model DBG-600BC . The only info I could get was on this site and I believe the guy had model 500 . I took the cover off the plastic piece to dismantle the basket after a coffee overflow and when I did the spring popped out . Well after an hour and a lot of swearing I got the darn thing back together and working Ok here's how it works for this model Keep in mind that the entire operation is done w the coffe maker in the upside down position .You have the spring with an end horizontal to the spring and the other end with an end perpedicular to the spring exactly like the model 500 - on the unit there is a plastic pin and in front of it a larger circle , which is where the spring goes The spring must push on the right side of the pin ( pushing it left ) in order to allow the latch to catch, this is the horizontal side of the spring and it has a left hook where it pushes on the right side if the pin The other side must push against the outside body of the coffee maker,just a little to the right of the hotizontal end .Place your left hand underneath where the pin is and lift up all the mechanism and with your right hand push the perpendicular side if the spring to the left until it seats up against the right side of the machine (That's why the entire right side if the plastic cover has no side because that's where the spring goes. Keep pushing up w your left hand - you should be able to place the plastic piece ( open side to the right and screw it down in place . I hope this helps
  • Johnn Ray Oct 28, 2021
    I wish there was a diagram or photo (I should have taken one before I took it off) because I still was thinking that each end of the spring had to go on opposite ends from the other and even though I read your instructions, it was still not clear to me and I was having an aggravating time trying to keep tension on the spring and then put the cover back on before it slipped loose. Then I finally figured out what I was doing wrong, and then I put both ends of the spring over on the same side, not opposite each other. Then I could bend the spring to where both ends almost met each other to supply the tension, (and now it was not sticking out so much on the other side that the cover could not be put on) and the tension was now enough to keep the spring in place long enough for me to put the cover over it and screw it in finally! Thanks!
Ivectoru
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 19, 2014
Ivectoru
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
6152
Points
7
The best solution I've found is to remove the spring that pops the door open. When you open the door there is a tab on the frame of the coffee maker close to the release button. Push that tab down and pull out the filter basket assembly. When you pull it out there is a spring that will either fall out or you will see sticking out of a tube in the back of the coffee maker.
You can either pull this spring out and put the assembly back in which will necessitate that you now have to pull the door open from the bottom when you push the release button, or you can clip part of the spring off making it weaker which will put less stress on the release button making it less likely the door will pop open.
I removed the spring completely and that solved my problem.
  • Anonymous Oct 10, 2021
    Note: This spring is not the same one as is discussed in the prior comments. The prior comments refer to the small two-armed spring that is inside the little plastic housing on the underside of the fixed rail on the left of the coffee maker. This comment refers to the long (~ 2.5 inch) spring that is inside the tubular compartment that is built into the shelf that slides on the rails. The small spring pushes on a lever that keeps the sliding shelf in place. Pushing the button on the side of the coffeemaker acts against that spring, disengaging the catch on the sliding shelf, allowing the larger spring to push the shelf forward out of the unit.
Cuisinart Grind and brew new coffee pot and the brew buttons to select brew size dont light up
To reset your Cuisinart coffee maker, start by unplugging it and then plugging it back in. Next, press and hold the button for three seconds. After that, press the button again and hold it for three seconds. Finally, press the button one more time and hold it for three seconds.
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
9helpful
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
My cuisinart grind and brew model dgb-700bc shuts off right before it is done brewing and i am getting coffee grounds in my coffee pot
Too much grounds or not running through fast enough. Right filters? basket flow hole vlesr? Sounds like it's backing up and flooding causing the grounds to get by yje filter. If you dare, **** the hole out just a tad. with the end of a sharp knife. not too much. You can always take out mor. This is called consuner calibration. Good Luck -Ned-
2helpful
3answers
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
2answers
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
2helpful
2answers
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
4helpful
2answers
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
I have a cuisinart automatic grind and brew thermal coffee machine. Soemtimes, during brewing, the container holding the grinds pops open and the still brewing coffee pours everywhere.
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
