If you can not hear the person at the other end, it means your phone has a hardware problem. The earpice of your phone is bad.
Swiych of the phone. Remove the battery. Get a screw driver, loose the screw and open the phone.
Gently remove the earpice and take it to the phone accesories store to get a replacement. Replace the new earpice with the old one and couple the phone.
Put your battery and switch on the phone and start making calls.
when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
hi, its your mouth piece that is faulty..when this is bad, when you call the other person at the other end will not be able to hear you..All you need do is to change the mouth piece. cheers.
The problem could be due to some contact error in the headphone jack of ur phone. Please re insert the headphone and remove it. Now try making a call with the speaker volume put to maximum. Dont forget to rate the solution. Thank You..
