Question about Frigidaire FAH085N1T Air Conditioner
No cold air
Unit will turn on but doesn't feel like it is blowing cold air. Have the fan on cool and temp all the way down at 60 and just blowing warm air. Wondering where i might start. Can't tell if compressor is running or not. doesn't sound like it is kicking in.
If unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Posted on Jun 29, 2008
I had same problem, try turning unit off for 5 minutes, also remove batteries from remote.. remote sensing ftl.. then turn unit back on, set unit to cold mode, fan high, increase temperature from 60 to 68.. or until compressor comes on... my compressor finally came on at 68 but wont work at 60.. hope and pray it runs till morning with the landlord can come replace it.
Posted on Jun 23, 2009
SOURCE:
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down...
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
Jun 26, 2010 | 2004 Chrysler Sebring
Maytag RSW24EO refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
Not Cole -- fan inside are blowing room temperature air
If after freeing the fan blade it still will not turn, you have a bad fan motor. (almost certainly due to it being restricted.)
That will cetrtainly cause it not to cool properly.
If the fan will not turn after freeing it, it will need to be replaced. If it does turn properly, unplug the fridge for about an hour to let the compressor cool down. Make sure all the coils vents etc are free of dust and dirt. Plug it back in, and if the fan is still operating properly, you should be back down to temp in a few hours max.
Aug 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Frigidaire FAH085N1T Air Conditioner Logo
1,341 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
