The link above is the manual on the Samsung and the page that you need to read and follow.
Select a wallpaper for the idle screen
1 In Idle mode, press [
2 Select an image.
3 Save or Set wallpaper.
Select
Samsung is not responsible for any use of default
images or wallpapers provided on your device.
Step 4
Tap the image you'd like to use as your new wallpaper from the list on screen. Then, tap "Set Wallpaper." Your wallpaper will be changed to the new image you have selected.
Microsoft Zune
Step 1
Turn on your Microsoft Zune.
Step 2
Select the "Pictures" menu option.
Step 3
Select a picture that you'd like to use as your Zune wallpaper.
Step 4
Select "Apply as Background" to change your Microsoft Zune background to reflect your newly selected picture.
This is just the background. It's set to dynamic or "live wallpaper"
To change follow these steps.
Step 1
Press the "Home" button to return to the main screen.
Step 2
Press the "Menu" button and tap "Wallpaper."
Step 3
Tap "Wallpapers" or "Live Wallpapers" to access the selection of preset wallpapers. Live Wallpapers are simply animated images, such as bubbles, clouds or smoke.
Step 4
Tap a thumbnail and then "Set Wallpaper" to apply it to the Home screen's background.
In mble s5233 three screnes are connected to each other in you images you see three photo wallpaper is already given and the images you are pasting n wallpaper that will be a smaller imzge than required.If you paste a big image then it will be divided into your mble's 3 screens...........:-D
If you want to get a picture on the front of your phone do this:
Go
to Menu--Settings--Display and Light--Wallpaper (If you have the
picture in the wallpaper gallery then select it and click 'Set' and if
you've got the picture in the different directory then go select
'images' and then go to the desired directory crop and click 'Set')
I would recommend this software Samsung Wallpaper Creator
small in size but handy for creating wallpapers for your mobile where
you can have 3 wallpapers in one and slide according to your choice on
the phone. Click on the link and go to the download Tab on the top
and download the Zip file which is of 2.5 Mb aprox. Install on the PC
and start creating wallpapers.You should use 240 * 400 size wallpaper
aprox.each in the box.N you can always search for the pics on Google. If there's more help you need let me know. Good Luck.
YES YOU CAN CHANGE THE MAIN SCREENS WALLPAPER. sIMPLY TRANSFER ANY BMP OR JPG FILE INTO YOUR IMAGES, THEN SIMPLY SELECT MENU, MY FILES, IMAGES, TOUCH THE IMAGE YOU WANT TO USE, SELECT OPTIONS, SET AS, WALLPAPER. OR GO INTO THE SETTINGS CHOOSE 'DISPLAY AND LIGHT SETTINGS', 'DISPLAY SETTINGS', 'WALLPAPER', 'IMAGES', THEN JUST SELECT THE IMAGE YOU WANT AS YOUR WALLPAPER.
