Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
SOURCE: 2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
