Goodman GMS90703BXA Heater Logo
Posted on Dec 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The thermostat is set to heat at a temp of 68 degrees. However,the thermometers temp read 71 and the blower was running and passing cool air. I tried setting the thermometers temp to 72. The furnace started (blower fan) but the gas did not fire up. Do I need a new glow plug? If so where can I buy them?
Andy
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 572 Answers
  • Posted on Jan 08, 2018
Andy
Master
Level 3:
Loyalty:
Answers
572
Questions
0
Helped
209724
Points
1498
Nothing is wrong with your unit according to your definition.
A unit does not shut off exactly at your set point ,so if you set it to 68 it would not shut off exactly at 68 plus when heat works fan would run even after flame is off to cool down the heat exchanger. There is also a dead band on every thermostat and it depends how it's setup
artie g
Level 3:
  • Master 873 Answers
artie g
Master
Level 3:
Answers
873
Questions
0
Helped
245713
Points
2752
The burners are not igniting and the timer turned on the blower thinking the burners were already lit by then. You have a burner/ignition problem. Either the ignighter or themocouple is bad
5 Related Answers
carldc3
carl carpenter
  • 82 Answers
  • Posted on Jan 13, 2009
SOURCE: Furnace blower never blows.
it sounds more like the flame sensor ( a metal rod that is by the burners with a wire going to it and it has a ceramic base). you can try cleaning the rod and if that doesnt work they are not to expensive.
Harisk Karameh
  • 68 Answers
  • Posted on Jan 20, 2009
SOURCE: with new digital thermostat furnace runs every 10 min.
You did not say what model you use. Depending on the model , there might be setting for 'deadband' or 'system type'. Changing that value will affect when it turns on. If it switches on that frequently and the room feels comfortable, it might be that your thermostat is placed on wrong place - one which cools of quickly, or there is draft cooling it off. Digital thermostats have a 'learning period' and adjust to dynamic of the room.
Anonymous
  • 80 Answers
  • Posted on Oct 07, 2009
SOURCE: I had a friend install my new Goodman GMH950704CX
The most common mistake on these after installation is not flipping the switch on the gas valve from 'off' to "On". Remove the top panel and in the middle of the cabinet the gas line comes into an aluminum looking device. There is a switch on top. If that is on, ensure that the gas has been turned back on.
Anonymous
  • 1420 Answers
  • Posted on Mar 09, 2010
SOURCE: furnace does not shut off
Easiest way to find out is to disconnect the thermostat or at least the red wire on the thermostat. If it stops, it's the thermostat. If it continues, you will need to disconnect the wire going to the R terminal on the control board. If it stops, it's a crossed thermostat wire. If it continues, its a problem with the control board or relay and you will need a technician.
Anonymous
  • 13 Answers
  • Posted on Nov 02, 2010
SOURCE: Goodman GMP075-3 not igniting. Everything cycles
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
My honeywell electric thermostat is on 70 degrees but my heater system for a moblile home blows cold air after it reaches 68 degrees why?
Thermostats have multiple issues when you start checking them against thermometers.
1) the built-in thermometer may not match the set temperature because one or both need calibration. Compare the built-in to an external thermometer and see if there is any adjustment to make them match. Record the setting on the thermostat and the temperature when it starts and stops -- there should be a 1-3 degree range which may be adjustable. The set point should be in the middle of the on-off temperature spread.
2) the thermostat has a heat anticipator setting which may be set poorly -- turning off the heat before it reaches the set point - the fan normally runs for 1-2 minutes after the heat source is off. The anticipator is used to stop heating before reaching the set point as there are still a lot of BTUs coming out during the fan run-down -- usually 1-2 minutes.
tip
Temp cut off/cut in
Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.<br /> Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree. <br />In cool mode, if you set at 68 C degree it will cut off at the end of 66 and cut in will be at the beginning of 70 degree.<br /><br />
on Jan 10, 2011 • Heating & Cooling
1helpful
2answers
Changed filter, held down f button to reset. Now won't cool, but unit is running.
Take it back apart and carefully reassemble it, you likely misplaced one of the components causing air bypass or not triggering an internal switch.
WHY DOES MY FURNACE SHUT OFF BEFORE REACHING TEMP
Hi Demetrio
Furnaces turn on and off based on what they're told by your thermostat. The thermostat, in turn, will control the furnace based on:
  1. The temperature AT the thermostat.
  2. What the internal heat sensor thinks the temperature of the air is.
So, if your idea of 68 degrees is what the thermostat thinks is 71 degrees (thermostat reads three degrees high), then when the air by the thermostat gets to about 65 degrees (by your account), it'll think it's 68 degrees and shut the furnace off.
Also, if the thermostat is, say, near a source of local heat, like a lamp, a big piece of electronics, a fireplace, or that place that you habitually set down your coffee, then the air right next to the thermostat may be warmer than the rest of the room, and fool it into thinking it's at it's target.
The sensor is usually inside the housing for the thermostat. If it hasn't been dusted in a while, then it can be hard for air to get inside to affect the sensor, though this would generally cause it to lag on readouts and run the temperature higher than you wanted.
If you have a digital readout, and the system is saying , hey, target is 68, and the readout gets to 66 and the system cuts off the furnace.... my only other guess is that the unit may have features that are trying to prevent overshoot - i.e. by the time the temp at the thermostat actually gets to 68, most of the room is more like 73. That'd depend on your particular thermostat. At that point, you may want to call customer service with the manufacturer and tell them the issue. There may be ways to adjust the unit to get behavior closer to what you seek.
Good Luck!
DH
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
I just got a new heating unit installed. However it runs constantly. If the target temp is 68 degrees it will hit 68 degrees and just keep running. It does the same at 63 degrees. Is this normal?
Dear friend! Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.
Hope it's helpful to you?
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
2answers
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Thermostat setting
what i would do is see if the outside unit is working at all. when you first turn it on the air was warm due to the fact that the temperature inside was cooler than the set point. when it get within 2 degrees the unit shuts off the backup heat and your running on the hp alone. with both stages at the same temp you are running the hp and the electric heater and that can become very expensive. What I would do is make sure that the filters were clean and look at the outside unit and see if it has a red reset button on it, if it does reset it and see if the unit runs. If it doesn't then you need to call a quallified service person out to take care of the problem.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
