I have no idea what it means for a Senao to "go to Realtek."
An RS-232 null modem serial cable is required for this procedure. 1. Connect the EOC-3220 to your computer with a null modem serial cable. 2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. 3. After the HyperTerminal window appears: a. Give this new connection a name. Ex: EOC-3220. b. Select correct COM port. Ex:COM1. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window. 4. Wait until the "#" is displayed in the HyperTerminal window. 5. Type "flash reset", then hit enter. 6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Here is the factory reset procedure for the Senao EOC-3220:
I also have de same problem, I have already tried the flash reset but it did not work. what caused the problem is that I upgraded the firmware with ital8186v6_1-en.
If you load non-Engenius firmware into this radio unit, all of the manufacturer's procedures become void. The non-Engenius firmware has no idea how to communicate with the serial port.
