SOURCE: My Goldstar dehumidfier is not working/producing
Humidistat won't cycle the compressor. Replace the sensor or put a timer on the compressor.
SOURCE: dehumidfier freezing up
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
SOURCE: WE have a gold star
Sounds like you're going to need a new bucket & float, if you want to continue to use the dehumidifier in any thing other than continual hose draining mode.Here's a link to where you can find a replacement bucket w/ the float valve included. http://www.appliancefactoryparts.com/dehumidifiers/partinfo.php?partsid=276540
I hope this helps and thanks for choosing FixYa.
SOURCE: Whirlpool AD70USR0 Dehumidfier - Our basement is
If it is very cold some of these consumer units will not turn on the compressor. If the unit suddenly stopped working and the temperature is room temperature I would guess a refrigeration issue- either a leak or bad compressor. Make sure the "full bucket" indicator light is not on- the condensate bin may not be plugged into the unit properly.
