SOURCE: Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
SOURCE: My Microwave oven makes a loud buzzing noise and
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
The
waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the
size of a playing card and often held in place by a plastic rivet.
In some models it is a
larger stirrer cover type made of thicker plastic in the ceiling of the
oven.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If your
waveguide cover
is burned, it will need to be replaced.
It provides critical
protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals
and installation instructions for Electrolux and Frigidaire
here.
Otherwise, you can find links to helpful exploded view
diagrams and part ordering help
here.
I recommend that you bookmark that
link to your favorites.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My Frigidaire microwave is less than a year old.
The symptoms of loud noise and no heat indicate a short in the magnetron or high voltage diode. Need to take it to a qualified repair, to figure out what the problem. The magnetron replacement can cost as much as a new oven. See what the warranty covers, maybe you might luck out.
Hi rajnherc, thank you for your post!
Based off the information you have provided you would like to unlock your Frigidaire microwave, FMT118EPB. I was unable to locate any additional manuals for your microwave. If it is an older model, over 10 years old, manufacturers will not keep material on them. You may be able to perform a generic search online for any further information. Good luck. -Matt
