I have bought a Kitchenaid pro 600, KPM26M1X, which runs on 110 V, from US. I want to use it on 230 V back in Europe. I suppose the motor 9707507 could be changed to another running on 230 volts. But what about the speed control (I think part.no is 9707220). Would I need to change the speed control too? Please help me out, I am probably not the first one asking about this! /HENRIK BERGMAN
After many years dealing with Kitchen Aid mixers I purchased a pro 600 for my wife as an early Xmas gift. After just a few usages it started making a clunking noise in the gear housing. I removed the housing and discovered the casting is of very poor tolerances and the main drive assembly was lifting from the torque of the motor and causing the gear assembly to lift out of the casting and skipping on the worm gear. I am sure it is going to happen to many more of these units as the casting area that holds the bearing in is to large obviously an overdue mold in the casting process. Time for a recall Kitchen Aid.
Sadly, there is a 95% chance that only the control board has been blown, not the motor. I have added a link below for you to purchase a new control board if you wish:
Hola de nuevo PASTELERIARU.Haga clic en este enlace al sitio web del http://www.kitchenaid.com.mx/Contacto.aspxKitchenAid Internacional para México. Espero que sean capaces de señalar a los vendedores de partes en México. Buena suerte otra vez, Howard, Burke, Inc. EE.UU. Si esta solución ha sido de ayuda, por favor vota, gracias!- Hslincoln
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
