Nokia 5320 XpressMusic Cellular Phone Logo
Posted on Oct 25, 2010
I have nokia 5320 xpress music and i forget my MMC password. kindly give me the solution, i also download the file of fexplorer but when i install the message appear "certificate error" kinldy help me. i also allow remote lock enable and type a message "abcde" but after this when i give the same message for mmc password the mobile do busy and no respond till i remove the locked mmc. kindly help me i m online. regards
G2less
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Nov 04, 2010
G2less
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
6053
Points
95
You need to formate your mmc..
  • m_rehanbhatt Nov 05, 2010
    when i go to format mmc it also take password for mmc.
I forget my 1 GB Micro SDmemorycard password how can i recover in Nokia 6260 slide
Hi
Please follow the mention below step and unlock your memory card.
Download the FExplore click here
1. Open any file manager softwares like Seleq, FExplorer.
2. (Search phone memory only)search for the file MMCSTORE in phonememory using seleq software's inbuilt search,
or search manually in folders either C:/SYSTEM/DATA or C:/SYSTEM/
Search by giving the search item as mmcstore.* or mmcstore.dat (better manually locate)(Seleq represents phone memory as c drive and mmc as E drive)
3. when you find it, send it to your PC by using send option in seleq.
4. on PC, open the file with Notepad, or any word processor
5. There goes your password.Ignore spaces and any unidentificable unknown (non english) charecters.
You can only recover the password of the MMC card set on your phone.
If the password for the card was set on another phone you would have to apply the above procedure on the phone which originally set the MMC password.
1helpful
2answers
My mobile nokia 5800 xpress music i forgot my password can u help me how to open micro sd 8gp card
Install fexplorer in phone memory. Then look in c drive of phone, you will find a file called mmcstore. Copy this file to yor computer and open it with notepad. At the end of this file yo will find your memory card password.
Thanks for using FixYa. Please rate the answer.
2answers
I cannot unlock my block memory card 4 5130 xpress music
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
4helpful
2answers
Nokia 3110 mmc problem
sir nokia 3110 mmc not show in gellry
5helpful
2answers
I forget my nokia password how to recover it or change it
your nokia password is 12345. if you didn't change ur code then it will be work.
Lost pas
Hai, Install Fexplorer You can download it here: Click Here!
Go to C:\system\mmcstore
press "option", select "file", select "Hex/Text Editor"You should be able to see the password!  Thats the password for your MMC.
From Truly,  Mr.Jestin   India.
1helpful
2answers
Mmc password for nokia n78
Copy the mmcstore file or send it to computer, rename it to mmcstore.txt and you will see your mmc password
3answers
How to unlock mmc
dear customer first of al thanx 4 choosing fixya...
first of al install fxplore in ur phone if not installed
1. Open one of above software you have. 2. Browse through the directory, C:\system 3. Rename the file mmcstore to mmcstore.txt 4. Open the file - The file will open in Notes. 5. You will find your password in that file. That file would also contain much more data which you do not understand,so you need to go through the file to get the password!
When ur cell is connected to pc by means of data cable or bluetooth,u can see the password by simply opening the file mmcstore with notepad.
I dont remember the password in memory card
What should we do if we forget the password? For S60 1st and some of 2nd phones, the password is stored in a plain text file.
  • Firstly, you need to install FExplorer a free file manager that allows us to browser through S60 file system.
  • Next, launch FExplorer and then browser to c:\system folder. There is a file, called mmcstore.
  • Rename the file to mmcstore.txt and then open it. Your password must be several characters at the end of the file.
1helpful
3answers
How to unlock mmc card
Buy an mmc clip unlocker, that'sth one solution i know.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
