Possibly faulty airmatic pump for suspension, first open boot and boot floor mat then have look on spare wheel, you can see your tools extra fuses and fuse diagram on it, take fuse diagram and read it you can find what's the fuse no and fuse box where is the airmatic pump fuse and relay is, check fuse and relay first, if the fuse blown replace same fuse for that now you know where are the extra fuses, get one from that, start engine is the car not rise up operate the switch above the radio still not working either faulty airmatic pump or control unit, you can check pump yourself turn steering fully left, remove clips from bulkhead inside wheel arch only need to remove front section then have a good look inside you can see airmatic pump is hanging on chassis rail under the right head light, have a good look wires on pump if it dried and broken that's the fault, only solution either repair pump or replace new pump. if not the faulty pump you have to get diagnose the car by experience technician, is this information helped you?
