This engine or notorious for valve cover leaks, faulty pumps not to mention faulty intake gaskets allowing water/oil mixture. It is very important when intake gaskets to torque the intake in proper sequence about 3nM each time to 8nM final torque. If you are sure the engine has not ran hot drain oil and water, then replace the intake gaskets. The kawasaki service manual is widely available online. Follow the torque sequence or surfer warped parts.
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Hi. Did you solve this? Besides choke, rich mixture can also be a sticky float (or faulty needle valve) - these allow a higher float level than normal, which will cause more fuel to flow thru the main jet and/or overflow into the intake. Another possibility is some kind of restriction in the intake upstream of the throttle plate (possibly a blocked air filter) - this increases the manifold vacuum for a given throttle settting, which also causes more fuel to flow thru the main jet.
PS I have a Kubota with a 20 HP Kawasaki V twin water-cooled engine - probably the same engine? I have WS manual - maybe I can help more? Let me know.
My 345 did the same thing and changing the module off time dely for $23.00 fixed the problem. I did all the stuff you mentioned but this was the problem.
Choke cable is fine as is the adjustment. Thanks anyway.
After flushing the fuel tank,draining the carb, and replacing the fuel lines I still had the problem. Put in a new set of plugs and the tractor is running fine now. Thanks for your input.
blow the carb vent tub back up through carb until gas seeps from it , then it will run right.
signed: John Deere small engine mach.
