Have you checked that it is not the amp that is the problem? This is a fairly common thing to have the amp heat up and the thermal protection shut it down partly. Since the bass drops, a loose connection or bad guitar cable can cause that. If the signal becomes capacitively coupled only the treble will come through and be very distorted. Try a new cable. For the guitar, open the electronics area and look for loose or broken wire.
Sound like symptoms of a bad \ dead battery. You could replace with new 9v Alkaline or invest some more and buy a rechargeable 9v Ni-mh battery with charger so you can charge every time battery gets low.
