1: Press the
button to turn off the screen. 2:
Press and hold the down arrow button until an 02 appears in the Roof
Temp, when you see the 02 appear remove your finger. 3:
Using the
button - short continuous
pushes until you see 02 on the top (Roof Temp) and 5 underneath (House Temp) NB:
The light should go off. 4:
Press the and this will save your
changes.
1. 2. 3. 4. 5. 6.
Turn off control panel using the POWER button
Hold down arrow pointing down for 8 seconds
until a 02 comes up where the roof temperature should be (a 01 comes up first
but keep holding until the 01 changes to a 02 - don't let go when you see 01).
Below the 02 will be another number.
Increase the 02 to 22 using the up arrow button
(not holding it down, short continuous pushes).
Below the 22 you will see a 0. Increase the 0 by
pressing the power button until you go up to 5.
Press the FUNC button to save your settings
& take you back to the main screen.
You will now see that the filter light has
switched off
Thank you works well
Hi there, do you have set up instructions for the HRV control panel. thanks Scott
Which button can safe the change? i could see the picture
SOURCE: fitted new filters in hrv
Hi cpttubwash,
We are glad that your problem has already been solved.
Listed information will help other people in the future with same problem as what you've encountered.
Have a nice day!
Thanks for using Fixya.
