My DVD DC-AVD8501 keeps shutting down. When I press the power butter to bring it out of standby, it displays the volume at 40, then says 'OFF' and shuts down again.
I have the same problem. All checked fro dry joints etc but to know avaial. Front right speaker also buzzes when unit is powered on I have the same problem. All checked fro dry joints etc but to know avaial. Front right speaker also buzzes when unit is powered on
You can't post conmments that contain an email address.
Mine did this last year, turns out there was some problem with the soldering on the circuit board. Take it to be looked at, easy to be re-soldered and cost me about £50.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
It will erase everything Hardware factory reset Take your phone and turn it off just press power button and select power off.Wait while your device is shutting down.Then, press volume down button and power button together until the LG logo appears on the screen.When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.Once you do that, on your LG G2 the factory reset menu will be displayed.Press power button in order to agree and wait while the hard reset is being completed.
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Hi jimhamilton, Try the following Link to get access to over 6 thousand four hundred Unlock Code Solutions http://www.videohelp.com/dvdhacks Somewhere on this list you should/will find you exact model to 'Unlock' Best of luck, techbuff
On your remote control (with tv off) 1. press Display, channel 5, Volume Up and then Power this brings up the service mode (you will see some green text on your screen) 2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen (channel 2 cycles up through the options, channel 5 cycles down) 3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro" (channel 1 cycles up through the suboptions, channel 4 cycles down) 4. Press channel six until the default value (12:60) changes to 12:40 (channel 3 increases the value, channel 6 decreases the value) 5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write" 6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Check for overheating. Place the unit in a large plastic bag and place it in the refrigerator for 1/2 hour. Don't allow condensation to appear on the unit before powering it up, the heat will evaporate any potential condensation. Put moisture absorber or rice in a paper bag in the plastic bag for safety to absorb any moisture. Then power up. If still inoperative check for DC or AC voltage on speaker connectors. If one side is different, or if DC appears on the outputs, audio output may be shorted. See if plugging in headphones stops the problem, some units disable the audio outputs with headphones plugged in.
