I had the same problem with the samsung s630 with the lens stuck open, I would turn on the camera and then it would beep 3 times then automatically turn it's self off. I tried using new batteries and chargeable batteries nothing was working and the lens was stuck causing the camera to shut down. I tried to twist the lens to get it unstuck, eventually it did get unstuck and now the camera is working fine.
My camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
My camera has done the same thing. However I have put many new batteries in it and still it will not work! it just freezes! even if i let it set! I have even tried leaving the batteries out.. and still.. NOTHIng!!!!!!!!!
My camera switches off when I have zoomed in as far as I can. The result is my camera is switched off but the lense is still out. I am now unable to switch back on.
camera just won't turn on I have already changed the batteries and still nothing
Samsung S600 was not working - Switch on - 3 beeps - Switched off again.
I noticed the Lens was not fully retracted and was able to wobble it with my fingers and ease it out a little - Switched the camera back on and it works fine - It may have received a knock on the lens after the battery went flat and not fully retracted - I use 2 x NiMh 2500 rechargeable batteries which last a fair while.
same problem with two samsung s630 cameras, working perfectly then lens stuck out and will not turn on,numerous new batteries tried,
