I have trouble with this every single time. What you need to do is remove the silver plate right under the needle. If you think of the case as the number 6, put the comma I just typed (a little piece of plastic sticking out from the rounded section at the bottom) under the metal at the bottom.
Then slide the metal plate at the top back on. You may need to turn the knob on the side of the machine (that makes the needle go up and down) to get it to go back on. At this point, as you're turning the knob, the bobbin case should fall back into place.
I just finished doing this myself. Now my issue is that the thread from the bobbin keeps knotting up.
Download your manual for free at www.singerco.com and enlarge the diagram, it will be alot easier to see. Good luck
