Husqvarna 125bvx Hand Held Blower Vac Logo
Posted on Oct 24, 2010
I have a Husqvarna 125B leaf blower with less than 10 hours on it. I checked the obvious things but it won't start. The carb is clean, it has a new plug. Are there any problems this blower is notorious for?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4263
Points
6
Run for 10-20sec. cut off
  • perks433 Nov 21, 2010
    I am having the same problem. It ran for about 5 mins and then cut off completely and now I can't get it started.
My husqvarna 125b leaf blower only runs on full choke. If I move it to half choke it dies. I've taken the carb out and cleaned it and that didn't help.
Sounds like the mixture is out - trial and error really or take to licensed repairer they will let you know if you need a new carb or whatever is stopping it from running normal :)
Good Luck!
Gas coming out exhaust on 125b husqvarna leaf blower why
Check the carb. sounds like the needle valve is stuck open allowing to much fuel the enter the piston cylinder. Carb. probably needs to be rebuilt.
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
5helpful
2answers
How to adjust carb screws on husqvarna 125b blower
You need a special carb screw tool for Walbro carbs. Readily available from eBay, search ''Carb Adjusting Tool for Partner/Husqvarna''
1helpful
Husqvarna only runs at half choke
Ours does the same thing. On Amazon you can buy the carb. adjusting tool for about $17 and will solve your problem. It solved ours.
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
1helpful
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
I have a Husqvarna 125B blower and when it sits for a few hours, it floods to the point that I've experienced licquid lock in the cylinder. This happens even when it is stored in the level horizontle...
you need to clean the carburator. the gas needle inside has dirt or needs adjustment. if you are not able to make it work then replace carb. part# 545081811 about 30.00 at sears website or service center.
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
